Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
Double-click the page on which to define the Employee Lines
Area. (This is the page with enhanced table images.)
On the Edit tab, select the page
area on which to place the Employee Lines Area.
Place the Employee Lines Area in the same content area on
the page as the Host Command Area and tables in order for the hosting
staff to access the functions and view information.
Click Other..., select Table Management, and then select Employee
Lines Area.
Adjust the size and placement of the Employee Lines Area
to ensure that it covers all enhanced tables on the page. Tables that
are not covered by the Employee Lines Area do not show server assignment
lines.
