Creating a Section Layout
- Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
- Create the page on which to define the Section Layout.
- Click Other..., select Table Management, and then select Section Layout.
- Adjust the Section Layout size to ensure that the text is visible to hosting staff. The text size scales with the Section Layout size.
- Click Save.
Related Topics
Parent topic: Dining Room Tables and Seating
