Configuring Table Management Privileges
- Select the Enterprise, click Configuration, and then click Roles.
- Select the role type, click the Operations tab, and then click the Guest Management subtab.
- Select the appropriate options for the privileges. The following table summarizes the privileges associated with table management functionality and the recommended roles to have the privilege set.
Table 52-4 Table Management Privileges
Tab Location Option Number Privilege Name Allows the Employee to ... Recommended Roles Guest Management
32020
Edit Section Layout
Edit a section layout
Host, Manager
Guest Management
32021
Activate Section Layout
Activate a defined section layout as the Active Layout
Host, Manager
Guest Management
32022
Delete Section Layout
Delete an existing section layout
Host, Manager
Guest Management
32031
Assign Employee to Table
Assign an employee to a table or section in TMS
Host, Manager
Guest Management
32032
Mark Table Clean or Dirty
Mark a table as clean or dirty
Host, Manager
Guest Management
32033
Change Table State
Mark tables as being Available, Closed, Reserved, or Merged
Host, Manager
Guest Management
32034
Seat Unsuggested Table
Seat a table request at a table that is different than the table that was suggested by the TMS Table Suggestion System
Host, Manager
Guest Management
32037
View Legend
View the TMS Legend and use the available functions contained within the form
Host, Manager
Guest Management
32038
Allow Seating Guest Above or Below Table Capacity
Seat a table request at a table that does not support a different seating capacity (other than the cover count on the table seating request)
Host, Manager
Guest Management
32039
Allow Seating Guest at Table that does not Meet all Required Table Preferences
Seat a table request at a table that does not meet all of the seating preferences defined on the table seating request
Host, Manager
Guest Management
32040
Edit Server Availability
Edit the server availability
Host, Manager
Ad Hoc Reports
31044
Run Employee Section Assignment Report
Run the Employee Section Assignment Report
Host, Manager
Transactions
22
Post Payment to Checks Belonging to Another Operator
Unseat a table request
Host, Manager
Transactions
37
Authorize/Perform Posting of Payment
Host, Manager
Transactions
38
Authorize/Perform Closing of Checks with a Zero Balance
Host, Manager
Guest Checks
18
Authorize/Perform Pickup of a Check Belonging to Another Operator
Host, Manager
- Click Save.
Parent topic: Dining Room Tables and Seating
