Configuration Guide POS Workstations Changing the Appearance of Workstations Changing the Appearance of Workstations Select the Enterprise, property, or zone, click Configuration, and then click Theme Assignment. Change the following settings: Default Theme: Select the default theme for the workstations. Default Palette: If you selected Edge as the Default Theme, select the color palette for the theme. Click Save. Parent topic: POS Workstations
