Click the Enterprise, Setup tab,
and then CAL Packages.
Select All from the CAL packages
tree.
Click the Deployment Schedules tab.
Click the Add Deployment link.
Figure 1-3 CAL Packages Deployment Schedules Tab
Click the down arrow under Choose CAL Packages
to upload to access the drop-down list, select CAL Client.xxx, and then select [file name] for the version
of Simphony you are upgrading to. The (xxx) refers to the version
number.
Figure 1-4 CAL Package to Upload Window
With the Deployment Type set to
the default setting of 1 - Property/Enterprise, click the ellipsis ‘…’ adjacent to the drop-down
list.
Select your property from the list, and then click OK to close the Select Properties list. Click OK again to close the CAL package selection window.
Verify the Action to Take column
shows Install, and then click Save.
Your workstations should begin receiving the CAL client updates.
