Suspend and Resume Checks
With Suspend/Resume you can:
Suspend a check started by another employee, and sign on to the workstation.
Suspend a check when the workstation automatically signs out an employee.
Suspend a check using the Suspend Order Tender/Media key.
When suspended, the check is stored in the memory until it is resumed.
Related Topics
Parent topic: Guest Checks
