Adding the Guest Room Number to a Check
After beginning a check, you can validate a guest’s room number and last name. This does not pre-authorize nor charge payment; it is simply a query through the OPERA Payment Driver to associate the guest’s room number and name on the check. During payment of the check, you can process the room charge without re-entering the guest’s room number and name.
Parent topic: Guest Checks
