Creating a Team Check
- Press the Begin Team Check function key, and then press Yes when prompted for confirmation.
- If you belong to multiple service teams, from the Team Service dialog, select the team for which this check belongs, and then press Select.
- If you have the privilege to create service teams, click Add to create a new team.
