Re-firing Items to the Order Device
If you have the appropriate privilege, you can use the Re-fire command to re-send items to the order device.
You cannot
re-fire items from the following types of checks:
                           Closed Checks
                           Training Checks
                           Waste Checks
                           Autofire Checks
The re-fire function is not supported with Dynamic Order Mode (DOM). Menu items configured with Timed Fire cannot be re-fired using the re-fire functionality.
Re-firing items is not allowed when there is activity in the current round.
Parent topic: Guest Checks
