Applying a Discount Manually
You can apply a manual discount to an entire check or to a single item on the check.
- Begin a check and add menu items.
- Select the button configured for the appropriate discount.
- If the discount is an open discount, enter the discount amount or percentage, and then click OK.
- If the workstation prompts, enter the discount reference details, and then click OK.
- To apply a discount to a menu item on the check:
- Select the menu item, and then select the button configured for the appropriate discount.
- Repeat Steps 3 and 4.
Parent topic: Discounts and Service Charges
