Voiding a Gift Card
If you are using SPI and you do not have privileges to void service charges from a previous round, when you attempt to void a gift card or a menu item that was added before the gift card (in the current round), authorization is required.
- Create a check with the gift card.
- Select the gift card.
- Press the Void function key.
Parent topic: Loyalty and Gift Cards
