Using PATT with One Credit Card
Complete the following steps when using PATT for a guest paying the entire check:
- Add menu items.
- Press the Pay at the Table (PATT) function.
- (Optional) Select a different language from the drop-down list to translate the entry fields.
- Tap Next on the initial PATT page.
- If the guest wants to change the tip percentage or amount, on the Add a Tip page, tap the Text field, enter a different tip value, and then tap Next.
- To send an electronic receipt with signature to the guest, enter a valid email address, and then tap Next. If the guest does not want to receive an electronic receipt, leave this field blank.
- Swipe the guest’s credit card.
- Enter the guest’s signature on the device, and then tap Next.
Parent topic: Check Payment
