Activating and Deactivating a Section Layout
Activate a layout to assign employees to sections and tables. Activating a new layout establishes the next employee to open a guest check on a table. Changing the active layout does not change the ownership of open guest checks.
Deactivate a layout to quickly clear all section and employee assignments for the tables. Tables with open guest checks appear with the Occupied status. Guest check ownership does not change when deactivating a layout.
- To activate a section layout:
- Click the Load Layout button.
- Select the layout to apply, and then click the Activate button. The layout appears as the active table layout.
- To deactivate a section layout:
- Click the More... button.
- Select Deactivate Layout. Assigned sections and tables disappear.
Related Topics
Parent topic: Dining Room Management
