Unseating a Table
If the guest wants to move to another table after being seated, you can unseat them and re-seat the guest at a different table. You can only unseat a table if the guest has not ordered menu items. After a guest check is open on a table, you cannot use the Unseat Table feature.
Perform a long-press on the table with the seated guest, and then select Unseat Table.
If the guest was previously seated from the Wait List, the guest’s name appears on the Wait List.
If the guest was previously seated using Quick Seat, the guest appears on the Wait List as QS in the guest name column.
Related Topics
Parent topic: Dining Room Management
