Configuring the Deployment Schedule to Install CAL on KDS
  1. Select the Enterprise, click Setup, and then click CAL Packages.
  2. Expand WS KDS Display from the left pane, and then select the latest KDS CAL package.
  3. Click the Deployment Schedule tab, and then click Add Deployment.
  4. Select 1- Property/ Enterprise as the Deployment Type, select a Property, and then select 0 - Install as the Action to Take.
  5. Click Save.
