Deploying the Media Viewer CAL Package
- Select the Enterprise, click Setup, and then click CAL Packages.
- Select Media Viewer from the left pane.
- Click the Deployment Schedule tab, and then click Add Deployment.
- From the Deployment Type column, select 2 - Specific Service Host.
- From the Service Host column, select the service host to download the CAL package, and then click OK.
- Click Save.
Parent topic: Media Viewer Configuration
