Preface
Oracle MICROS Simphony is a cloud-based Point-of-Sale (POS) solution that provides business management capabilities using a single tool with vast integration capabilities to property management systems, paperless kitchen display systems, credit card interfaces, and reporting applications.
Purpose
This Simphony Client Deployment Guide provides instructions about how to deploy clients for Simphony for the latest release.
Audience
This document is intended for system administrators of Oracle MICROS Simphony.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received and any associated log files
Screen shots of each step you take
Documentation
Product documentation is available on the Oracle Help Center at https://docs.oracle.com/en/industries/food-beverage/pos.html.
Simphony eLearning
The Simphony Learning Subscription provides additional product knowledge through interactive training, guided video tours, and helpful knowledge checks. After exploring the documentation library, use your Oracle Single Sign On to check out the Simphony learning opportunities at Hospitality Learning Subscriptions.
Revision History
| Date | Description of Change |
March 2023 |
Initial publication. |
June 2023 |
Added the Castles S1F2 Mobile Order and Payment Terminal Considerations topic to the Android Devices Chapter. |
October 2023 |
Updated the Configuring an Android Workstation topic in the Android Device Workstations chapter. |
January 2024 |
Updated the Installing the Android Service Host topic in the Android Device Workstations chapter. |
