5 Rappi
Rappi is supported with Simphony release 19.4 and later. Review the following checklist before you set up Simphony for Rappi:
  • Decide on your menu. Rappi supports one menu.
  • Decide on unique tag names for the menu.
  • Plan the list of menu items.
  • Determine menu availability. For example, will the menu be available only on weekdays between specific times?
  • The menu can have multiple categories but must have at least one category. A category is a group of similar menu items. For example, you can have a lunch menu with categories for salads, sandwiches, and desserts.
    In Simphony, a category corresponds to a SLU. Each category needs its own SLU.
    Rappi supports a maximum of 100 SLUs.
  • Decide on an image to display the menu. This is optional.
  • Consider the following characteristics of each menu item:
    • Customer-facing menu item name
    • Customer-facing menu item description
    • Menu item image that meets the following specifications:
      • JPEG or PNG file format
      • Pixel size of 1920 x 1080
      • Aspect ratio of 16:9
      All images are manually verified by Rappi and will not appear immediately on the ordering site.
    • Menu item price
    • Allergen classes
