Preface
Oracle MICROS Simphony is a cloud-based Point-of-Sale (POS) solution that provides business management capabilities using a single tool with vast integration capabilities to property management systems, paperless kitchen display systems, credit card interfaces, and reporting applications.
Purpose
This guide explains how to set up delivery service providers to connect to Simphony.
Audience
This document is intended for system administrators of Oracle MICROS Simphony.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received and any associated log files
Screen shots of each step you take
Documentation
Product documentation is available on the Oracle Help Center at https://docs.oracle.com/en/industries/food-beverage/pos.html.
Simphony eLearning
The Simphony Learning Subscription provides additional product knowledge through interactive training, guided video tours, and helpful knowledge checks. After exploring the documentation library, use your Oracle Single Sign On to check out the Simphony learning opportunities at Hospitality Learning Subscriptions.
Revision History
| Date | Description of Change |
March 2023 |
Initial publication for Simphony 19.5. |
May 2023 |
Added Skip chapter. Added Postmates to the Uber Eats chapter. Added Disabling Delivery Platforms to the Getting Started chapter. Updated Registering with Rappi in the Rappi chapter. |
July 2023 |
Updated Deliveroo. Updated Introduction to Delivery Connectors. |
October 2023 |
Added Deactivating Third Party Delivery Aggregators to the Getting Started chapter. Updated Configuration Checklist in the Getting Started chapter. |
September 2024 |
Updated Configuring Customer-Facing Content in the Deliveroo chapter. |
February 2025 |
Removed Glovo chapter from document. |
