Navigating the Home Page Using Keystrokes
- To place focus on the Location panel on the left, press Ctrl+H.
- To expand a level (Enterprise or property) to show the locations beneath, press the right arrow key.
- To move between the locations in the hierarchy, press the up arrow key and the down arrow key.
- To open a module:
- Press Ctrl+T to move focus to the tabs on the right, and then press the up arrow key and the down arrow key to move between the tabs.
- Press Tab to navigate to the first focusable element in the tab.
- Continue to press Tab to navigate through the modules in the tab.
- Press Enter to open the module.
