Creating Delivery Configuration in the Revenue Center
Configuration for delivery service provider platform integrations is specified in EMC through the Data Extensions column named DeliveryPlatformConfigurationData, which is added to the revenue center table, populated with the JSON representation of the data structure.
  1. Select the property, click Setup, and then click RVC Configuration.
  2. Double-click the revenue center, and then click the Data Extensions tab.
  3. In the Column field, locate DeliveryPlatformConfigurationData, and then click Edit Json.
  4. Enter JSON configuration data and then click OK.
    See Sample JSON: Glovo for descriptions of JSON data values and code samples that you can copy and change for your restaurant. After you change the sample values, you can copy your restaurant code into the DeliveryPlatformConfigurationData column to complete this step.
  5. Click Save.
