Using the Simphony POS Client and Mobile Solution Application on One Device
Your organization can run Mobile Solution 18.1 (used with Oracle Hospitality Inventory Management and Oracle Hospitality Materials Control) on a Simphony tablet device. To share applications on the device, you need to configure a button (using the Page Design module in the EMC) that closes the Simphony POS client on the device. (Minimizing Simphony does not release the scanner.)
When the device is powered on, the Simphony POS client starts automatically.
The workstation operator must click the Close Application button to stop the Simphony POS client.
The workstation operator must manually start the Mobile Solution application.
After using Mobile Solution, the workstation operator must stop it.
The workstation operator must manually start the Simphony POS client.
Related Topics
Parent topic: POS Workstations
