Configuration Guide Check and Posting Service (CAPS) Configuring CAPS on Microsoft IIS with Oracle Database on Remote Service Host Preparing the Server to Configure CAPS Preparing the Server to Configure CAPS Ensure that the Server has the latest Microsoft Windows patches. Turn on the Microsoft Windows features: Microsoft .NET Framework 3.5 Microsoft IIS Install Microsoft .NET Framework 4.6.1. Install the Oracle Database 12c Server database. Deselect the pluggable database option. Select the database admin user system account or equivalent. In the EMC, configure the CAPSOnIIS CAL package for deployment to the Remote Service Host. Install the CAL client on the Remote Service Host. In the EMC, deploy the CAPSOnIIS CAL Package to the configured Service Host. After completion, this package is available in the [Drive Letter]:\Micros\Simphony\CAPSonIIS folder. If you are using Oracle Database 12c Release 2 for the CAPS database, complete the following steps: Navigate to [Drive Letter]:\Micros\Simphony\CAPSOnIIS\Tools\ODP.NET_12CR2, and then follow the instructions in the Readme. Run the ODP.NET_12CR2.bat under the current directory with administrator privileges from a command prompt. During batch file execution, the status appears in the Command Prompt window. After successful execution of the batch file, close the Command Prompt window. Parent topic: Configuring CAPS on Microsoft IIS with Oracle Database on Remote Service Host
