Configuring Pickup Next Check by Check Open Time
You can configure a function key to pick up the next check by open time. This function allows a workstation operator to pick up the next check based on the time the check was opened.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Double-click the transaction page on which you want the pickup next check by check open time function key to appear on the workstation.
- On the Edit tab, select the page area in which to define the Pickup Next Check by Check Open Time key.
- Click Button.
- On the General subtab, enter the
button name in the Legend field (for example,
Pickup Next Check by Check Open Time). - Select Function from the Type drop-down list.
- Click the black arrow directly beneath the Type drop-down list.
- Enter
pickin the Name field, select Pickup Next Check by Check Open Time in the Results list, and then click OK. - Position and size the button on the page. Use the Style arrow to change the color.
- Click Save.
Parent topic: Guest Checks
