PreviousNext
JavaScript must be enabled to correctly display this content
Adding and Moving Widgets
From the Widget list, tap the widget to add.
To move the widget to a new grid location:
Tap the widget. A move icon appears.
Tap the move icon, and then tap the new grid location.
Widgets move based on tapping the left corner (upper left corner on large widgets) and automatically resize when moved to a smaller section of the grid.
