Creating a Content Record
For multi-tenant environments using releases earlier than Simphony release 2.9, you are required to configure the content information as Extension Application content. The content feature cannot be used in these environments.
  1. Select the Enterprise, property, revenue center, or zone, click Setup, and then click Content.
  2. Insert a record for the PMS content, named PMS.
  3. Double-click the new record to open it.
  4. Select 4 - String as the Content Type.
  5. Enter the following string in the Content tab and make the necessary modifications, as shown in the following figure (the content text file is delivered with the other files).
    See OPERA PMS Interface Settings for more information on the configuration strings.
    Figure 60-4 Content Text File
    This figure shows the Content text file that must be edited.
  6. (Optional) For debugging purposes, add the line "DEBUG_ON=10".
    This increases the verbosity, adding additional messages in the Egateway.log file.
  7. To override the Content, select the Use Existing Record option.
    The Content can be overridden by property, zone, or revenue center.
    Figure 60-5 Override Record Controls
    This figure shows the EMC override control.
  8. Click Save.
  9. Restart the Service Hosts.
