Click the Enterprise, Setup tab,
and then CAL Packages.
Select All from the CAL packages
tree.
Click the Deployment Schedules tab.
Click the Add Deployment option.
Click the down arrow under Choose CAL Packages
to upload to access the drop-down list, select KDS Handler x.x.x, and then select [file name] for the
version of Simphony you are upgrading to. The (xxx) refers to the
version number.
Ensure the Deployment Type is set
to 2 - Specific Service Host from the drop-down
list, and then click the ellipsis ‘…’ adjacent
to the same setting.
Select the workstation or server which is defined as the
KDS Controller for your property, and then click OK to close the Select Specific Service Host list. Click OK again to close the CAL package selection window.
Verify the Action to Take column
shows Install, and then click Save.
Your workstations or server should begin receiving the KDS
Controller update (or at the scheduled time).
If you have a backup KDS Controller, repeat all of the
previous steps for that device.
