Basic Security Considerations
Install the software securely. For example, use firewalls, secure protocols using TLS (SSL), and secure passwords.
Learn about and use the Simphony security features. Keep up to date on security information.
Keep the software up to date by installing the latest product releases and patches as soon as possible. See the Critical Patch Updates and Security Alerts website, located at http://www.oracle.com/technetwork/topics/security/alerts-086861.html to access this information.
Limit user access to necessary job functions. Review user privileges periodically to determine relevance to current work requirements.
Monitor system activity. Establish who should access which system components, and how often, and monitor those components.
Parent topic: Simphony Security Overview
