Preface
Oracle MICROS Simphony is a cloud-based Point-of-Sale (POS) solution that provides business management capabilities using a single tool with vast integration capabilities to property management systems, paperless kitchen display systems, credit card interfaces, and reporting applications.
Purpose
This document provides security reference and guidance for Oracle MICROS Simphony.
Audience
System administrators installing Simphony
End users of Simphony
Customer Support
To contact Oracle Customer Support, access My Oracle Support at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received and any associated log files
Screenshots of each step you take
Documentation
Product documentation is available on the Oracle Help Center at https://docs.oracle.com/en/industries/food-beverage/pos.html.
Revision History
| Date | Description of Change |
March 2023 |
Initial publication. |
March 2023 |
Updated Property Ports in the Appendix A: Simphony Property Ports chapter. |
July 2023 |
Updated Enterprise Ports in the Appendix A: Simphony Port Numbers chapter. |
February 2025 |
Added and updated the following topics located in the Simphony Security Overview chapter:
