Suspending and Resuming a Check
To suspend a check, the workstation screen should be free from prompts and error messages. When you suspend a check, the workstation posts the check to the database but does not print it. Suspended checks are not shown in the Open Check SLU (Screen Look Up).
Related Topics
Parent topic: Guest Checks
