Reprinting a Closed Check
You can reprint the check for a closed transaction in the current or previous business dates, and you can reprint a receipt for the last closed check. You need to have the appropriate privileges to perform these operations.
- To reprint the check for a closed transaction:
- Press the Reprint Closed Check function key.
- Select the check to print, and then press OK.
- To reprint a receipt for the last closed check, press the Reprint Previous Closed Check function key. The receipt prints.
Parent topic: Guest Checks
