Posting Checks to a Closed Event
You can add a check to an event that is closed. For example, when you end a wedding event at the workstation, and then a wedding guest orders a last minute drink, you can post that check to the closed wedding event.
You must have the privilege to associate a check with an event that has ended.
Related Topics
Parent topic: Events
