Select a parent menu item that has required condiment groups. The Popup Condiment Orderer appears.
Select a required condiment. The Popup Condiment Orderer automatically advances to the second group, and so on until you have selected the required number of condiments from all groups.
After you meet the minimum count, click Done to move to the next condiment group or to close the Popup Condiment Orderer.
If you click Done without selecting the minimum count of a condiment group, the application remains on the current condiment group and the Done button text changes from Done to whatever is needed (for example, Select 2 to 3 Steak Sauce Current Count:1). When you use devices running the Android mobile operating system, you receive an error stating that the required condiment group is not complete for the parent menu item.
To modify a previously ordered required condiment:
Select a menu item (condiment or parent) in the check detail area. The Condiment Edit Popup appears if it is configured from the Enterprise Management Console (EMC) RVC Parameters or Menu Item Classes modules.
To edit a menu item when the Condiment Edit Popup is not configured:
Select the menu item (condiment or parent) in the check detail area.
Click the Recall Popup Condiment Orderer function key.
