Pick up a check from the previous service round from the
Open Check SLU.
To directly refill the items, select the menu items to
refill from the check, and then press the Refill Auto function key or the Refill Interactive function
key.
To refill items from a list or to view a list of all refillable
items on the check:
Press the Refill Auto function
key or the Refill Interactive function key
without selecting any items on the check.
From the Select Items to Refill dialog, select the items
to refill, and then press Refill.
To close the dialog, press Close.
If an order quantity was specified when adding a menu item
in the first round, enter the number of refills when prompted.
For example, if a party of four ordered 4 glasses of Orange
Juice in the first round, when you attempt to refill the order, the
workstation prompts you to enter the number of refills. The initial
menu item quantity is taken as the maximum quantity (in the aforementioned
example, the maximum quantity is 4 when refilling).
When refilling
multiple menu items with quantities, you must enter the refill quantity
in the order that the menu items appear on the check. That is, the
first entered number of refills is taken as the refill quantity of
the first menu item, the second entered number of refills is taken
as the refill quantity of the second menu item, and so on.
