Clocking In and Out
Employees assigned to one or more one job codes must clock in. When a workstation is offline but can communicate with other workstations and services, employees can clock in. When a workstation is offline (no network communication) and unable to communicate with other workstations and services, employees cannot clock in.
If your organization uses Labor Management and Simphony is configured to automatically clock out and clock in when changing revenue centers, the system prompts you to do so.
- Click the Clock In function key.
- If you have multiple job codes, select the job code, and then click OK.
- If you have privileges, change the revenue center, and then click OK.
- Close all guest checks before clocking out at the end of a shift unless you have the privilege to clock out with open checks.
- Click the Clock Out function key.
Parent topic: Start of Shift
