Reloading and Refreshing the Check and Posting (CAPS) Database
You can reload and refresh the Check and Posting (CAPS) database. The following table explains the difference between each database action.
Table 1-5 CAPS Database Actions
Action | Description |
Reload |
Use this method to update the database of CAPS workstations |
Refresh |
Use this method to start a background job to download any configuration changes from the central database made since the CAPS workstation’s last database update. |
- To reload the CAPS database, click the Reload CAPS function key.
- To refresh the CAPS database, click the Refresh CAPS function key.
Parent topic: Basic Workstation Operations
