Configuring the Deployment Schedule to Install CAL on KDS
- Select the Enterprise, click Setup, and then click CAL Packages.
- Expand WS KDS Display from the left pane, and then select the latest KDS CAL package.
- Click the Deployment Schedule tab, and then click Add Deployment.
- Select 1- Property/ Enterprise as the Deployment Type, select a Property, and then select 0 - Install as the Action to Take.
- Click Save.
Parent topic: Client Application Loader (CAL) Setup for KDS
