Disabling Load Balancing and Enabling Capacity Scheduling
KDS load balancing is not supported when using KDS Capacity Scheduling.
- Select the property, click Setup, and then click KDS Controllers.
- Double-click the KDS Controller record to open it.
- On the General tab, deselect 8 - Enable Load Balancing, and select 13 - Enable Capacity Scheduling.
- Click Save.
Parent topic: KDS Capacity Scheduling
