You can change the name of a custom package, its deployment
order, and its platform type.
Select the Enterprise level, click Setup, and then click CAL Packages.
Expand the Custom subgroup, and highlight the appropriate
custom CAL package.
Change the following information on the CAL
Package Configuration tab:
Name
Deployment Order: Enter the order in
which to deploy the CAL package.
CAL packages with a value of
0 (zero) are loaded first. Custom CAL packages (not hotfixes) need
to start with 1000. CAL Deployment Order contains more information.
Platform Type: Select the type of platform
to receive the CAL package.
In the Limit To Services section, select specific Service
Host types to deploy to workstations.
If you do not select a service, the package deploys to every
Service Host based on the deployment schedule.
If you select one or more services, the package deploys only
to Service Hosts that run selected services. That is, when you configure
a new service for the existing Service Host, there is no additional
deployment for the Service Host. If a CAL package exists that is specific
to the service, the Service Host downloads it immediately.
For
example, if you select Cash Management, you must also select the Check
And Posting service (CAPS) because the Enterprise Cash Management
(ECM) module only runs on CAPS Service Hosts. This causes all Service
Hosts that run CAPS to automatically download the ECM CAL package
if a deployment schedule exists for the Enterprise or property.
