Configuring the Deployment Schedule to Install the Simphony Client on Workstations
When a hotfix is added to the CAL deployment schedule, the system automatically deploys the major Simphony version (for example, 19.2.0.0) first, followed by the hotfix.
When using Distributed CAL (DCAL), you must add both the major version and the hotfix to the DCAL download schedule. After the download occurs, it is made available in the DCAL server. Then you can schedule the POS client update.
- Select the Enterprise, click Setup, and then click CAL Packages.
- Click the Deployment Schedule tab, and then click Add Deployment.
- In the Choose CAL package to upload dialog, select 2 - Specific Service Host as the Deployment Type, click the ellipsis (...) point button adjacent to the drop-down list, select the appropriate workstation, and then click OK.
- Click OK to close the Choose CAL package to upload dialog.
- In the Action To Take column, select 0 - Install, and then click Save.
- Select CAL Client from the left pane, and then repeat Steps 3 through 6.
- Select Service Host Download from the left pane, and then repeat Steps 3 through 6.
- Select Service Host from the left pane, and then repeat Steps 3 through 6.
