Configuring CAL Package Permissions
- Select the Enterprise level, click Configuration, and then click Roles.
- Double-click the role record assigned to the privileged user (for example, administrator, manager, or server).
- Click the EMC Modules tab.
- Scroll to the Hardware section and search for CAL Packages. Based on your preferences, select the desired checkbox to assign View, Edit, Add, and Delete privileges to the role.
- Click Save.
- Repeat these steps for each role as needed.
