Configuring an Android Workstation
Perform the following tasks before installing the Simphony software:
Configure the Android device to be a member of the POS network using a static Internet Protocol (IP) address.
Install antivirus software on the device.
Turn off Trusted Sources on the device. See the manufacturer instructions for details.
Complete the following device configuration steps:
