Sample JSON: Uber Eats
The following sample shows JSON code for Uber Eats. The tables that follow the code sample describe the values in the code.
Tip:
Click Copy to copy the code to your clipboard and then paste it into a text editor such as Notepad++. Change the values for your restaurant and then copy your code into theDeliveryPlatformConfigurationData column as described
in Creating the Delivery Configuration in the Revenue Center.
"deliveryPlatformConfigurations": [
"name": "Uber Eats",
"groupIdentifier": null,
"rvcIdentifier": "984e0f54-64dc-15T3-e348-16942gs5arn5",
"empNum": 990,
"otNum": 4,
"remakeOtNum": -1,
"tendNum": 101,
"priceSequences":
"type": "BaseItem",
"levels": [2]
"type": "Condiment",
"levels": [6, 7, 8]
"condimentGroupRuleFilter":
"values": "1,2,3,4",
"include": true
"itemImageSlot": 2
"sluSlot": 1
"menus": [{
"name": {
"en-US": "AllDayMenu"
"identifier": "UberEatsAllDayMenu",
"imageURL": null,
"availability": [{
"dayOfWeek": "Mon",
"startTime": "00:00",
"endTime": "23:00"
"dayOfWeek": "Tue",
"endTime": "23:00"
"dayOfWeek": "Wed",
"endTime": "23:00"
"dayOfWeek": "Thu",
"endTime": "23:00"
"dayOfWeek": "Fri",
"endTime": "23:00"
"dayOfWeek": "Sat",
"endTime": "23:00"
"dayOfWeek": "Sun",
"endTime": "23:00"
Table 6-3 Data Extensions Column Name
| Name | Type | Description |
deliveryPlatformConfigurations |
DeliveryPlatformConfiguration[] |
Revenue center’s integration configuration for each applicable delivery platform. |
Table 6-4 Delivery Platform Configuration
name |
string |
Uber Eats Do not change this value. |
groupIdentifier |
string |
Set to null because the object does not apply to Uber Eats. |
rvcIdentifier |
string |
Identifier for revenue center. This is the Site ID obtained during the registration process. |
empNum |
number |
Object number for employee to be used to enter orders received from the delivery platform. |
otNum |
number |
Object number for Order Type to be used for orders received from the delivery platform. |
remakeOtNum |
number |
Set to -1 because the object is not valid for Uber Eats. Do not change this value. |
tendNum |
number |
Object number for Tender Media to be used to settle orders received from the delivery platform. |
priceSequences |
string number |
Type of base menu item and condiment (optional). Number is the price level. |
condimentGroupRuleFilter |
number true/false |
Numbers separated by commas. Numbers are the condiment groups. True directs the application to use the numbers listed. False excludes the numbers listed. |
itemImageSlot |
number |
Menu item image slot number used for the product display in the delivery platform. |
sluSlot |
number |
Menu item SLU slot number used for the product display in the delivery platform. |
menus |
DeliveryPlatformMenu[] |
Details for menu(s) to be submitted to the delivery platform. Make sure to follow any limitations imposed by the delivery platform on the number of menus. |
Table 6-5 Delivery Platform Menu
name |
TranslatedString |
Display name for menu, by locale. |
identifier |
string |
Identifier for menu to be used in tags. Ensure that the identifier will not conflict with tags used for other purposes. |
imageURL |
string |
Uber Eats does not support a menu image. Set to null because the image URL does not apply to Uber Eats. |
availability |
ServicePeriod[] |
Start and end times for each day of the week that the menu is to be made available. |
Table 6-6 Translated String
<locale code> |
string |
String translation for given locale. |
Table 6-7 Service Period
dayOfWeek |
string |
First three letters of day of week for service period. |
startTime |
string |
Start time for service period, in 24-hour (hh:mm) format. |
endTime |
string |
End time for service period, in 24-hour (hh:mm) format. End time must be later than start time. |
