Keyboard Shortcuts
Table 7-1 General Keystrokes
Keyboard Shortcut | Result |
Tab |
Navigates to the next focusable field or element from top to bottom and left to right. |
Down Arrow |
Varies based on context:
Up Arrow |
Right Arrow |
Left Arrow |
Delete |
Deletes the record selected. |
Enter |
Triggers the activity, when the focus is on a link or a button. |
Insert |
Adds a new record. |
Alt+E |
Accesses the Edit menu on the toolbar. |
Alt+F |
Accesses the File menu on the toolbar. |
Alt+H |
Access the Help menu on the toolbar. |
Alt+V |
Accesses the (Table or Form) view menu (where applicable) on the toolbar. |
Ctrl+C |
In Table view, copies the record or records that are selected. |
Ctrl+F |
Opens the Find dialog which allows you to search for records by entering a search criteria. |
Crtl+G |
Opens the Go to Record dialog which allows you to go to a record by entering the record's object number. |
Ctrl+H |
In the Home page, moves focus to the location hierarchy. |
Ctrl+K |
Closes all open modules, including the Home Page, and disconnects the user from the EMC. |
Ctrl+O |
Opens the EMC Login page when disconnected from the EMC. |
Ctrl+P |
Print records while in Table view. |
Ctrl+Q |
Closes the module that is active. |
Ctrl+S |
Saves the changes. |
Crtl+T |
Ctrl+V |
In Table view, pastes the copied records. |
Shift+F10 |
In Table view, opens the right-click menu when the focus is on a record. |
F3/F4 |
In Table view, allows copy and paste of fields. F3 copies the content in the cell and moves to the cell in the next row. F4 pastes the contents and moves to cell in the next row. This allows you to continually press F4 (or hold it down) and paste the same information to multiple cells in the same column. |
F8 |
Opens the EMC Record Translation dialog. |
Parent topic: Accessibility
