Condiment Group Filter
The condiment group filter lets you specify the condiment groups for each delivery service provider. The filter allows the condiment groups in the Menu Item Classes module to be included or excluded. This prevents unwanted condiments and condiment groups from being displayed on the delivery service provider ordering site.
To specify the condiment group filter in the JSON code, set condiment
group numbers separated by commas, and true
or false
to indicate whether the condiment group specified
will be included or excluded from the delivery service provider.
See Sample JSON: Rappi for a description of JSON data values and a code sample that you can copy and change for your restaurant.
Parent topic: Configuring Advanced Menu Item Options
