Using Default Condiments with DoorDash
If you have default condiments configured for a menu item in Simphony, you can pass them to DoorDash without having to create additional Menu Item Classes and condiment groups.
- If the condiment group is configured as a Default Condiment master group in the Menu Item Classes module, these condiments display as removable option in the delivery platform.
- If the condiment group is not configured as a Default Condiment master group in the Menu Item Classes module, the condiments display as selected items for the menu item, and must be disabled to remove them.
The condiment group configuration affects the way Default Condiments
display on a Kitchen Display System (KDS) and on order receipts.
- In the case of #1, a Hamburger menu item with Lettuce, Tomato, and Pickle as the Default Condiment master group displays as Hamburger, no, Lettuce
- In the case of #2, a menu item with lettuce, tomato, and pickle as the Default Condiment master group displays as Hamburger, Tomato, Pickle
Parent topic: Configuring Advanced Menu Item Options
