Image Slot
If multiple image slots are in use for an organization, the item image slot lets you specify which menu item image slot is used for the product display in the delivery service provider, rather than the default setting of 1. This feature is used with kiosks and online ordering sites.
See Sample JSON: Skip for a description of JSON data values and a code sample that you can copy and change for your restaurant.
Parent topic: Configuring Advanced Menu Item Options
