Price Sequence Level Filter
The price sequence filter lets you specify the menu item price sequence levels used in the delivery service provider. You can apply the price sequence filter to base menu items (for example, a hamburger) and to condiments (for example, cheese). This filter affects all menu items that are passed to the delivery service provider.
See Sample JSON: Skip for a description of JSON data values and a code sample that you can copy and change for your restaurant.
Parent topic: Configuring Advanced Menu Item Options
