Registering with DoorDash
If you are unable to locate your Simphony Home URL (OpenID Provder URL), it’s located in the EMC Enterprise Parameters module, Applications subtab.
When copying this URL for access to Simphony Home, exclude the/oidc-provider/ portion
of the URL.
- Complete the Get Started DoorDash form, located at https://get.doordash.com/en-us, and sign up for a merchant account.
- Establish a store in DoorDash for each revenue center that will process DoorDash orders.
- Advise DoorDash that this is an Oracle integration.
- You will receive store IDs for each store created.
- Complete the Simphony configuration steps detailed below.
- You will receive a menu preview link following your first successful menu sync (as shown in the Verifying Setup section).
- Advise DoorDash that the site is ready for use, and they will perform final activation.
- You will receive a confirmation email that your site is ready for use.
Parent topic: DoorDash
