Adding a Nutrient Set
When using Uber Eats/Postmates, you have the option to add a Nutrient Set for a menu item. Only the Calories nutrient type with either Calories or KiloJoules units are supported.
  1. Select the Enterprise, property, or revenue center, click Configuration, and then click Menu Item Maintenance.
  2. Search in the master records, and then select the menu item from the list.
  3. Click the Nutrition subtab.
  4. Click Add.
  5. In the Nutrient Set column, click the ellipsis (), select the Calorie nutrient from the drop-down list, and then click OK.
  6. Click Save.
